Push Rod Guides Necessary?
I am building a 346 LS1 with worked 799 heads, LS6 springs, LS7 lifters, 02+ LS6 camshaft and stock LS1 rocker arms with the Comp Cams trunnion-upgrade. Are push rod guides necessary? Will they help in this application - a 2000 A4 mostly driven on the street, not revved above 6000?
I have searched for about an hour and haven't determined whether the rockers are self-aligning or not. I remember my 383 was built with PR guides, but that was because it had roller rockers. So the main question is, do I need PR guides? And more of a general curiosity question, do LS heads have PR guides pressed into the head casting or are the guides simply the casting bore?
LS1Tech Premium Sponsor
Agreed, the factory rocker has a trunion that is bolted to a pedestal which aligns the rocker.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
