5.3 turbo build - swaping in a ls6 cam
Well i have been searching around for more information with regard to swaping in a ls6 cam. Seems to be pretty popular for Turbo builds. The numbers on the cam seem to be pretty good as well.
My questions is when swaping into a 5.3 can the lifter, pushrods, rockers and timing chain be reused? I am swapping in a set of gmpp yellow springs but have not been able to find any definative info regarding the rest of the components?
2. Where is the ls2 chain available? Dealer? any other cheaper sources? PN# if you have it?
Thanks.
Ok so got the timing set squared away with yank.
As for the pushrods it sounds like what everone is refering to is just a standard 5/16 diam. - 7.40" length ?
MILLSMOTORVATION - Whats the reason you went with the longer 7.45"?
