turbo V8 firebird in v6 shell
Year: 2013
Make: Pontiac
Model: Firebird
Price: $20000
Mileage: 62000
Private or Dealer Listing: Private Listing
Location (State): MI
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
Fuel system- Aeromotive fuel rails with twin walbro 255 lph fuel pumps. -8 braided feed with -8 filter and -8 y block at firewall. -8 feeds each rail seperatly and 80 lb/hr injectors per cylinder feed the hunger. An aeromotive a-1000 -6 regulator relieves fuel pressure through a -6 return line that runs back to the tank.
Cooling system- 160 degree thermostat with aluminum 3 core racing radiator. Aluminum Allstar catch can.
Chasis- 12 pt gusseted cage with door bars. BMR tubular K member. BMR Transmission cross member with torque arm relocation. BMR secondary cross member with driveshaft loop. SLP 6 pt subframe connectors. BMR th350 crossmember with torque arm relocation. UMI Tubular k member.
Rear End- DTS built 12 bolt. 1350 billet yoke detriot tru trac. 3:73 gears. Arp extended wheel studs, Moser axles, DTS billet girdle cover. (
Tires- Rear 315/40R16 Mickey Thompson et streets. Front 225/60R16 passenger tires
Transmission- TH350 with blue frictions and hardened steels. Forward Manual Valve body, Yanks eliminator 4000 ls1 torque convertor, TCI SFI flex plate, hardened input and output shaft. 1350 yoke. Hardened drum and sprag. Hurst pistol grip quarter stick shifter. Custom driveshaft built for 1000hp
Engine Bottom End- Eagle H beam rods with Wiseco -20cc forged pistons and hellfire rings. Eagle forged 4340 crank. ARP main stud kit. Clevite TRI-Armored bearings. ATI harmonic balancer
Engine Top End- Cadillac CTSV R lifters, Texas Speed Chromoly 7.4’’ push rods. Yella terra roller rockers, Leading Edge Performance Turbo Camshaft, LS2 roller timing set with Texas Speed ported oil pump. Precision Race components double valve springs with titanium locks and retainers. Heads are a 317 casted ported stock ls1 head with larger titanium intake valves 2.02” and 1.6’’ titanium exhaust milled to 55 cc’s. Cometic head gasket seals up the top end along with ARP head studs and an ls6 intake combined with a BBK 85mm throttle body. ARP head studs
Gauges- Autometer ultra lite trans temp, boost, and coolant temp gauge along with full sweep electric oil pressure gauge.
Braking System- line lock with factory braking system
Turbo System- Garrett gt4294 turbo. Dual TIAL 38mm wastegates regulated by a turbo XS manual boost controller. TIAL blow off valve and 1000hp intercooler. Tial blow off valve
Interior- procar racing seat with 5 point harness. Sparco steering wheel
Steering/Suspension- Tubular rear lower control arms. Adjustable tubular panhard rod. Edelbrock tubular torque arm with relocation kit. Eibach springs in rear and Edelbrock IAS shocks/ manual steering rack and pinion.
Exhaust- forward facing cast iron manifolds with stainless hot side piping, stainless wastegate piping, and stainless down 4’’ down pipe that splits into dual 3’’.
Electronics and Tuning- Factory 2002 z28 pcm with modified wiring harness to bare essentials. Tuned through HP tuners via their MVPI PRO tuning software and 3bar sd tune. Battery relocation kit to RR wheel well.
