Sponsor Sales & Specials - Xtreme Performance Transmissions Year End Sale + LS7 Clutch $425
Johnny@Xtreme_Trans
12-17-2011, 04:02 PM
2 Year Warranty on all our transmission and converter combos
No Transmission Core Needed
4L60E Level 2 Transmission $1495 or $2130 with Billet Converter +Free Shipping
• Hardened pump rings
• Servo D ring kit instead of Teflon
• New Accumulator Pistons
• Modified Pump Assembly
• Oversized Boost Valve
• High Quality Overhaul Kit, Frictions and Bushings
• Xtreme Transmissions Shift kit
• Borg Warner dual cage 29 element Input Sprag
• Corvette 2nd gear Servo kit
• Wide rear sun gear bushing
• Heavy duty sun gear shell “The Beast”
• High energy 2-4 Band
• High Energy 7 friction clutch pack with full thickness Kolene Steels
• Teflon Pump Bushing and Extension Housing Bushing
• Built with Performance Tolerances and Lube Modifications
4L60E/4L65E Level 3 Transmission $1895 or $2525 with Billet Converter +Free Shipping
• New electronics
• 4th gear billet servo kit
• Billet 2nd gear Servo kit
• Upgraded Bearing Type Reaction Carrier Shaft
• Wide 2-4 Band with Reinforced Anchor
• New 4L65E 5 Pinion OEM Front and Rear Planetary Set
• High Energy 8 friction clutch pack with full thickness Kolene Steels
• Input drum Steel sleeve prevents input drum breakage at spline area
• 2-3 Shift Valve Upgrade
4L80E Level 2 Transmission $2395 Or $3150 with Billet Converter +Free Shipping
4L80-E up to 800HP
Completely Rebuild with Quality Rebuild kit
High-energy Performance frictions
Bonded pistons
34 element intermediate sprag
Xtreme Transmissions shift kit
New solenoids
New OEM Filter
New sprags
New Trans-go Spacer plate
New speed sensors
6 Direct frictions instead of 5
HD Int. Snap Ring
Billet Forward Hub
No core needed
4L80E Level 3 Transmission $2800 Or $3500 with Billet Converter +Free Shipping
4L80-E up to 1000HP
Bonded pistons
New solenoids
New OEM Filter
New sprags
New speed sensors
HD Int. Snap Ring
Billet Forward Hub
300M Input Shaft
300M Intermediate Shaft
No core needed
TH400 Street/Strip Transmission $875 or $1150 with High Stall Converter +Free Shipping
6L80E and 6L90E Performance Rebuild -- CALL
TH400 Race Transmission with Trans-Brake $1425+ free shipping
Race frictions
300m input shaft
billet steel hub
pro-tree rev. pattern transbrake
billet snap ring ring retainer
deep aluminum pan
LS7 Clutch Kit = $425+shipping
6L80E Billet Converter any stall (2800-4000) $755+Free Shipping
4L60E Billet Converter any stall (2800-4000) $695+Free Shipping
4L60E Deep Cast Aluminum Pan $135
TH400 Deep Cast Aluminum Pan $95
4L60E 300M Input Shaft $339
4L60E 300M Output Shaft $445
6L80E 4340 Intermediate Shaft $650
4L80E 300M Input Shaft $320
LS1 OEM Flexplate $55
LT1 OEM Flexplate $49
BigDaddyBry
12-26-2011, 09:40 PM
What HP levels for the Level 2 and 3 4L60E units?
Thanks.
Johnny@Xtreme_Trans
01-05-2012, 04:45 PM
Thanks.
Level 2 is rated to 600hp and the Level 3 to about 750hp.
Johnny@Xtreme_Trans
02-04-2012, 12:59 PM
Sale has been extended till the end of February
