Wet Kit on a stock LS1?
NOS is to Nitrous as Kleenex is to Facial Tissue. People have issues with you calling it NOS. Anyway...
150 wet is no problem with all the safety equp. Window switch, WOT, etc. People blow their motors spraying at too low of RPM. You should be 3000+. or going lean. Not enough fuel. If you are not going to upgrade your fuel system. I would stay around 125 for good measure.
Thanks, I want to buy the NOS kit..that is what I ment by it. Marketing is everything! What is the window switch? I will upgrade the fuel system too, but help me with what I need to buy..
Thanks is advance..
Thanks is advance..
Thanks is advance..
Thanks is advance..
Fuel upgrades mean bigger injectors and fuel pump.
You should contact a sponsor and get all the info from them, they can hook you up with what you need.
Thanks is advance..
Thanks is advance..
It is all in the FAQ
On my set-up I have a window switch 3200rpms and 6000rpms. This means at wide open trottle you start spraying at 3200 and pulls the spray out at 6000 automatically. That way I don`t spray threw shifts and hurt tranny. Upgrade fuel system just to be safe and get a good tune. Its like insurance, well worth it I promise. I love it! Check Sig!
How does the LS1 hold up to NOS? Looking about 150 shot wet kit..Will I grenade the motor?
Thanks in Advance!
Thanks in Advance!
Originally Posted by beardWS6
That way I don`t spray threw shifts and hurt tranny. Check Sig!
If you are not going yo beef up the tranny it is a good idea.
