Used Innovate Motorsports LM-1 wideband kit
Category: Engine - Electrical
Price: $265
Part Fits: Corvette, 04-06 Pontiac GTO
Location (State): PA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
The LM-1 by Innovate Motorsports is the industry's first and best complete O2 AFR wideband tuning system. A single self-contained unit combines a wideband air/fuel ratio sensor controller, a 6-channel data logger, and an easy-to-read backlit LCD display. This is the unit used by tuners, racers, and engine builders the world over.
Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meters digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
World's only fully-digital wideband controller.
Up to 6 Channels of data logging.
Portable/ Handheld.
Display both A/F and Lambda readings in real-time.
Auto calibration to compensate for changes in temperature, altitude, and sensor condition.
Two user configurable analog outputs.
LogWorks - award winning tuning software.
The LM-1 Wideband Controller / Data logger can sample and store 6 channels of data- air-fuel-ratio and up to 5 other sensor data channels- internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included LogWorks software or any standard spreadsheet program:
The Innovate LM-1 also features two analog outputs to connect to analog gauges, dyno computers, ECUs, piggyback controllers, and other devices with analog inputs. Analog output 1 comes setup from the factory ready for narrowband simulation; analog output 2 is configured as 1 volt = 10 AFR (.6 lambda) and 2 volts = 20 AFR (1.3 lambda). With the provided LM Programmer software these analog outputs may also be configured by the user.
1. The LM-1 Basic Kit (this p/n 3723 you're looking at here) includes the Innovate Motorsports LM-1 meter, a Bosch wide-band oxygen sensor, 10 ft sensor cable, cigarette-lighter power adapter, serial cable for PC connection, 9V battery, exhaust bung and plug, CD and quick-start guide.
