408 turbo on a 98PCM?
In the spring I am hoping to run a 408 turbo and was just wondering if my 98 pcm will be ok with this? What do i need to change/ what should I do?
You can do that just fine. Just get a 2 bar map sensor, cut a few tables in half and you are good to go. A road runner ecm from moates also makes the job a little quicker.
Or if you dont want to mess with the 98 ecm, then a swap to a 99 up ecm is in order. Then you can run custom operating systems for boost.
