What does this dyno graph say about the tune?
Old 12-25-2011, 08:27 PM
sworaz's Avatar
Default What does this dyno graph say about the tune?
Looking at buying this car but I'm concerned about the street tune it has.
Motor is healthy and was compression tested by speed inc . It is a si5 cam, bolt on ls6 with ls1 heads.
Old 12-26-2011, 10:01 AM
wait4me's Avatar
Looks like it just lost spark plug input from thier sensor on the dyno.
on another note, The dip from 3200 t o 4200 making you lose 26ft of torque could be wheel spin, missing timing, to much timing and getting kr,or a dirty air filter.
The spikes/ missing sections on the run are from the spark signal being lost. If it wasnt the actual sensor, then it was possible that it was a missfire on that cly, However, that would be more rare than just it being the sensor being wrong.
I would also Richen up the cal a bit too. Shouldnt hurt power any, but will be a bit more safe.
Old 12-26-2011, 04:58 PM
edcmat-l1's Avatar
Ya can't tell anything about how a car drives, or how good the tune is, by a dyno sheet. All you can tell is the power, WOT A/F, and subtle things like if it has spark knock, or knock retard under WOT.
Quick Reply: What does this dyno graph say about the tune?
