Pontiac GTO 2004-2006 - 2005 gto
megan.roush13
12-28-2011, 07:17 PM
I have a 2005 GTO with a auto transmission that I recently bought and I am needing a new rear end for it because only when I turn left or right it makes a loud clicking/popping noise. When I took off the bolt on the diff cover I looked at the fluid and it had fine metal shards in the fluid. Anybody know anything about this? Or know what I should do? It only has headers, stall, custom exhaust and tune done to it so a stock rear end would be fine or should I upgrade? Thanks :)
outkast6991
12-28-2011, 07:24 PM
Try changing the fluid first. Mine was popping and a fluid change took care of the noise . Seems to be common with these cars
scphilli
12-28-2011, 09:40 PM
use torco and friction modifier
thehazz12
12-28-2011, 10:36 PM
Can't help you with why that happened or how to fix it, but I can offer some help with your question of replacing or upgrading. So you recently bought your GTO (so did I)...what are your goals for it? Do you plan on leaving it as is or further modifying it? If you plan on racing it some you still might be ok as the a4's are less destructive to the rest of the car than m6's are but my question to you is: While you already have to fix or replace the one that is in there, why not just upgrade it? You may go through another rear end if you simply replace it so spending extra $$$ on an upgrade may make sense. If getting the funding to do that is a problem (nothing wrong with that at all...I would be in the same boat) then disregard my previous comment. Hope that helps.
Congrats on getting the goat.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
