SFC Ground Clearance ISSUES?
Old 03-16-2004, 02:35 AM
Nick D's Avatar
Question SFC Ground Clearance ISSUES?
Does anyone know if putting Subframe connectors like the ones from BMR will reduce ground clearance? Does my 99 WS6 have them already and would they need to be removed or do these just mount on top (or bottom I guess) of the floor pan. Any pics would be great! Thanks. Also will these interfere with anything else under the car?
Old 03-16-2004, 05:31 AM
DARK AGE 53's Avatar
Very little if any clearance lost, your y-pipe will be lower then the SFC. I like bolt-on SFC's over the weld-on SFC but it's car. Your WS6 does come from the factory with SFC's, I'll get you a link to the install.
Al
Old 03-16-2004, 05:33 AM
Weld-on's-- http://www.bmrfabrication.com/instructions/sfc001.htm
Bolt-on's-- http://users3.ev1.net/~cnl1/firehawk/subframe/index.htm
Quick Reply: SFC Ground Clearance ISSUES?
