ls2 vs lq9 block for a 350 shot
Ive been trying too see if a which block would be better to go with if im spraying a 350 dual stage nitrous system...
no i do not car about weight if i want too loose 80 lbs ill take a **** its not a honda i just want too hear from guys who know and have experince from high nitrous shot's like this and if you go with a alum. block do you have too get it sleeved or what is my only option a iron block the problem im running into is finding a iron block...
You can sleeve if you want but if you run that high of a n20 ratio for a long durration you could see block failures. Not nessesarliy cracking but I deffinitly have seen warping and fatigue. Would highly suggest an iron block for any wet n20 system that will be used in a racing or frequent app. in my opinion.
