SOLD FLT LEVEL 5 4l60E AND VIGILANTE 4000 CONVERTER (PRICE REDUCED)
Category: Drivetrain
Price: $1400
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO
Location (State): NY
Item Condition: Used
LS Engine?: Fits LS Engine
$1400 for the transmission obo plus shipping SOLD
$650 for converter obo plus shippingSOLD
Click on picture below.
FLT machined performance pump.
Media blast case, bell housing, and tail housing to restore a new aluminum finish. Prep case for assembly.
FLT sleeved input drum
FLT (billet 6061 aluminum) overrun piston
Sonnax SmartShell w/bearing kit
GM 5 pinion input carrier
GM 5 pinion reaction carrier
Bearing style reaction shaft
New reverse input drum
Alto wide 2-4 carbon lined band with reinforced anchor
8 B/W hi-energy clutches w/koleen steels in 3-4 clutch
Extra Wide Heavy Duty double caged 29 element sprag
4L65 low roller clutch
Corvette Servo
Sonnax super hold 4th servo
Bushing kit
New solenoids
New Internal wire harness ( If needed on 4L70E )
New Spacer plate
B/W clutches
Seal & gasket kit
Filter
GM deep pan
Updated aluminum accumulator pistons
FLT calibrated valve body w/ HD 2-3 shift valve modification
Set end play to FLT specs
Case cooler fittings
