p0068 dtc
p0068 dtc
understand its a MAP/throttle body correlation problem... Yes it has a new 2 bar MAP sensor, but I can assure you it is not vacuum leak, and the MAP sensor is reading properly...
I too am leaning to a faulty TPS as the truck is very jerky at light throttle, the throttle body is a new nw 102 dbw any insight will help thanks.
