Need to locate 2 pins...
Ok well i repin my 98 pcm to a 01 5.3 0411 pcm, but i cant find where to plug the tan wire that comes from the obd 2 port and the black wire from the map sensor. Im using a painless harness can someone help me out?
I have an after market harness, I will take a look tomorrow i have a purple and a tan from the obd2 port, and on a diagram i was checking it say the purple is the Class 2 serial data that goes to blue 58, and on a another says the tan goes to blue 58 so i got confuse, and from the map i have a black wire i will take a look tomorrow to make sure.
thanks for the info 2xLS1
Ok from my map sensor i have a lt green, gray, and orange with black. I can't find where to plug the orange with black, and a tan wire coming from the Obd2 port.
I have a purple coming from the obd2 port that is named like serial data.
