MAF Housing/wiring question....
Old 01-12-2012, 04:40 PM
Project Revision's Avatar
Default MAF Housing/wiring question....
I have a Magnuson Supercharger (ls2 from a 2006 GTO) that I am currently wiring through a donor harness from a 2001 TA. Question is this: I need a MAF housing - as the build will require a MAF housing that fits the 06 GTO, will the wiring be the same for hookup to my 01 ECM?? If not, any conversions or suggestions out there?
Thanks!
Brett
www.project-revision.com
Old 01-12-2012, 08:18 PM
Anyone?
Old 01-13-2012, 05:39 AM
LS1MCSS's Avatar
I would think the MAF wiring would have to match the PCM, whether you're using the GTO pcm or the f-body pcm.
Old 01-13-2012, 09:40 AM
garys 68's Avatar
Is your 01 ecm from an f body with separate MAF and IAT? Is the ecu a 411? Is your 06 LS2 24 or 58x reluctor?
Old 01-13-2012, 11:44 AM
Thanks for the replies gentlemen.....Gary, you'll have to forgive me - this is my first LS build so I'm learning quite a bit as I go (I'm certain you've never heard that before :-) ). The LS@ is a 24x......I believe the MAF and IAT must be combined (connector has three wires going in; 2 connectors to throttle body, and one to front left cylinder head). As for the ECU, no clue.....ANY help is greatly appreciated!!!!
Old 01-13-2012, 05:15 PM
garys 68's Avatar
The 411 ecu was run on some f bodies and will work with cable and DBW TBs. I dont think it can run ANY 4 bolt LS2 DBW TBs, but maybe can get an aftermarket 4 bolt cable TB to work. Speartech may have an adapter.
The 411 will run the separate MAF/IAT or the combined MAF/IAT. I'm not sure if repromamming is needed though. Same PN on 02 truck combined MAF/IAT as 06 GTO. You might try buying the combined plug.
Old 01-16-2012, 11:24 PM
Spear tech was able to answer my question and provide a solution - thanks guys!
Quick Reply: MAF Housing/wiring question....
