Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
ARE Stg 2 heads 2.05 1.60 65cc
Old 01-13-2012, 10:46 PM
enginjoe's Avatar
Default ARE Stg 2 heads 2.05 1.60 65cc
Category: Accessories
Price: $500
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): AZ
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Agostino Stage 2 Heads done on 241 castings. 65cc chambers
Manley 2.055 intake valve and 1.60 Exhaust valve.
This is a quote from original owner:
"All hand ported, I was impressed. they do flow 300 at .600, I could not find the flow chart though. They were ported originally and then updated later by Agostino.
they have Comp Cams dual springs, I forget what the part number is though.
I just finished these up, they were dismantled, I bead blasted the heads to clean them up nicely, everthing but the deck was done. Every part is spotless or as close as you can get anyway. reinstalled with new Viton valve seals. The valves were lubed properly, there was no reason to replace the valve guides though.
These saw limited action at the strip with about 5k total miles.
The only small problem with the heads is a stuck accessory bolt on one head that has been cut off nearly flush. it can be taken out or the heads flipped around if you even need the hole. every other hole has been completely chased clean."
I bought these from the above owner and they are in great condition and everything he said they were. My problem is that they won't work with stock rockers because the springs and valves are SBC. So, either you need aftermarket rockers, shim your stock rockers for clearance or have the valves and springs replaced with LS1 stuff. I already have brand new stock rockers with trunnion upgrade and new Lunati springs, so I can't use them with these heads.
SOLD $500 shipped SOLD
Old 01-14-2012, 04:22 PM
enginjoe's Avatar
bumpage...
Old 01-14-2012, 10:27 PM
enginjoe's Avatar
Heads are sold!
