Synergy 2 step all in one box.
Category: Engine - Electrical
Price: $125
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO
Location (State): IA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
The first box is our "All in One" box. This box contains our Two step function, adjustable window switch, nitrous controller, purge, ect. What that means is we are able to use the box in place of the relays on your nitrous kit. The box will now act as your gateway for all controll over your purge, and your fuel and nitrous solinoids. It also has protection from open circuit, short, and over voltage with full LED status to let you know whats going on. There is also an overheat protection as well. The window switch will be adjustable in increments of 100 rpm like most other units out there. The two step will function the same way. On the purge, you have a mode switch from automatic or manual function. In the manual function you can set it up as a burst or solid state so you can adjust how it purges. The box also has a seperate output for either controlling signal to a bottle heater or bottle opener. Of course you will need seperate electronics for those too, but it will basicly allow you to signal to the other devices to arm or activate.
The unit is also fully upgradable at anytime. Customization is also optional upon contact with us to fit your needs. www.synergeymotorsports.net
The active cost right now for this All in One box will start around 350$ im asking 125$ shipped.
