Stock roller rockers and valve spring kit with trex cam
Just put in a trex cam been reading up that a good way to go on roller rockers is to stick with the stock ones and just buy the COMP Cams LS Series Trunnion Upgrade Kit should I go that route or buy after market rockers. Also wanted to know if I can use my stock retainers/locks for the Pac 1518 dual valve springs ill be buying or should I upgrade that I'm a student on a budget so that's why I'm asking will be shooting 150 shot of nitrous every now and then if that helps on the decision making
Thanks
Thanks
