LT1 won't start
Old 03-17-2004, 06:20 PM
sftaws6's Avatar
Default LT1 won't start
My buddy has a 96 camaro and it won't start. He needs to pop the cluch to get it started. He has already changed the starter but is still having the problem. Any help would be appreciated.
Anthony
Old 03-17-2004, 07:54 PM
wrencher
wrencher's Avatar
Ignition switch, clutch switch, pass key system, could all be at fault.
Any more info besides no crank must push start?
Old 03-17-2004, 07:57 PM
35th SS's Avatar
check your optispark.dirt,oil,moisture inside.
Old 03-18-2004, 09:39 AM
LS1CMR's Avatar
i had this problem with my 00 z28, it was the bmc, ignition switch, and pass key, cost the dealer abot 900 bucks to fix, if it has a security light does it flash while trying to start if so then that is the problem
