quick question
quick question
so after a long tube install ( done several months ago) if i change the front o2 sensors ( used denso) but reuse the stock rear ones for the rear o2 sensors ( which i did ) will this cause the motor to constantly try and compensate for what it thinks is a deffective cat by adjusting A/F? im having a bad idle problem that is getting worse and was fixed my replacing my front o2 sensors ( used the stock ones right after the install) but now im having the same problem. i have another thread titled "idle issues getting worse" for more info if needed.
trying to see if a tune would correct my idle problem by deleteing the rear o2 and compensating for the lt and bbk intake install. as well as the AIR delete
