A body p/s pump to gear clearance issue
Old 01-20-2012, 08:21 AM
Kingstir's Avatar
Default A body p/s pump to gear clearance issue
I have been trying to resolve some driveline angle issues in my 70 el camino/ ls2 install. I have raised the tail of the transmission since i cant lower the front of the motor. now I have the return tube to the P/S pump sitting on the pressure inlet to the gear. Can I turn the p/s pump completely over and make it work?- or do I need a plan b? Thanks for any advice.
Attached Thumbnails A body p/s pump to gear clearance issue-img_0273.jpg   A body p/s pump to gear clearance issue-img_0274.jpg
Old 01-20-2012, 12:29 PM
bczee's Avatar
What did that pump come from ?.. as well as the front accessory setup ? GM or aftermarket ?
Old 01-21-2012, 07:55 AM
Kingstir's Avatar
The P/S pump is the factory model from the 2006 GTO that the engine came from. The accessory drive is set-up is from Kwik Performance.
Quick Reply: A body p/s pump to gear clearance issue
