any 1000rwhp+ mast or prc headed cars?
getting ready to do a big turbo build...
anyone running a pair of mast 285 or 305 ls7 style or prc 6 bolt heads making over 1000rwhp?
havent seen any crazy builds with either....
Twin Snail Build
https://ls1tech.com/forums/texas-mem...56-magnum.html
Nitrous Build
https://ls1tech.com/forums/generatio...-1000rwhp.html
All I could find right now.
Nitrous Build
LS1Tech Premium Sponsor
We have a local car that has made well over 1000rwhp with the PRC 285cc heads on a Z06 with LSx block & twin 67mm turbos.
What bore setup are you considering? That will best tell me how i'd setup the cylinder head for you. We can send them setup with whatever valve configuration you want, and could even set it up with that nice PAC solid roller spring in case your going solid!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
