4l80 harness with 4l60
Old 01-24-2012, 09:15 PM
AJK381's Avatar
Default 4l80 harness with 4l60
Im getting a 6.0 donor truck to swap in my s10 but the truck has a 4l80 and i want to use a 4l60. Ive heard harnesses can be repinned to use an 80 on a 60 harness so im sure it can go the other way. I did a quick search and didnt find anything. Can anyone point me in the right direction? Its an 01 truck btw. Thanks
Old 01-24-2012, 10:17 PM
mantycarguy's Avatar
I just did this to my harness within the last week. I orderded a new 4l60e replacement pigtail from EFI Connection. Most of the 4l80e wires will match up to your existing harness. You will need to add I believe two wires for the tcc solenoid. I would also order some replacement pins from the same place. Compare the pinouts from a 2000-2002 1500 Silverado to a 2000-2002 Silverado 2500HD as both would have had these transmissions installled from the factory. If your not sure, please feel free to PM me. I see your in my home state.
Old 01-25-2012, 12:15 AM
AJK381's Avatar
Ok ill check it out. Im getting the truck tomorrow and will Have my buddy get me a diagram. Im guessing its gota be flashed to the 60 software for correct shifting?
Old 03-13-2012, 12:46 PM
m8w6r77's Avatar
https://docs.google.com/spreadsheet/...ozNlE&hl=en_US
I got this from somewhere not sure tho. Hope it works posting from my cell.
