Help figuring out which 5.3 I have
Old 01-27-2012, 12:29 AM
bakomack's Avatar
Default Help figuring out which 5.3 I have
5.3 iron block alum 862 heads DBW was told it came from 05 Tahoe/Yukon
I don't know vin or engine code can anyone help me out here
Old 01-27-2012, 12:56 AM
Track_FC's Avatar
Sounds like an LM7.
http://en.wikipedia.org/wiki/GM_Vortec_engine
Old 01-27-2012, 08:36 AM
the_merv's Avatar
LM7 5.3l, should have the 24X Crank.
Old 01-27-2012, 11:20 PM
bakomack's Avatar
How do I tell what crank? Any way to identify the engine when it's installed?
Old 01-28-2012, 03:24 AM
the_merv's Avatar
Pull Crank Sensor..if it looks like two seperate pieces of metal, 24X.
Old 01-28-2012, 11:22 AM
Bo185's Avatar
Its a Gen III 24x motor. Crank trigger will be colored black. The Gen IV 58x one's are grey. Also if it was 58x it would have the side mounted knock sensors as well as the front cam sensor.
Does it have returnless fuel rail? If so it probable on 04 up motor aas some 04 were RL rails by 05 most all the trucks had RL rails. Also look at the injectors and see if it has the flex fuel units to see if its a flex motor.
Quick Reply: Help figuring out which 5.3 I have
