Used Magnacharger for your truck
Destroyer of Transmissions
Category: Engine - Power Adders
Price: $3000
Part Fits: 2010+ Camaro
Location (State): OK
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
This blower has about 40K on it. It’s not going to win any beauty contests but it works great. Most of the box 2 items from my TVS2300 install are still sealed in the packages as I just swapped head units with my TVS. I did steal 2 hoses…I think that was all. I’m sure there are a couple of small things you would need to pick up like hoses or clamps, but all the big items are included. It currently has the returnless fuel block on it and the pics show another brand new returnless block. The box 2 was setup for a 2007 and later SUV I believe. Check out the valley cover, that may help. I also have two style heat exchangers. One is new and for the TBSS (I THINK), the other 2 are the standard truck heat exchangers. One is brand new; one is used, but works fine. You will get all three. Magnacharger boost gauge included. I’m throwing in the Magnacharger license plate trim at no added cost to you. You’re welcome.
42 lb/hr Ford Green top injectors are included. They flow higher at Chevy’s 60psi fuel pressure. I was good on fuel at 9psi on my 6.0L with this setup. There is a 2.9” pulley on the blower and I will throw in the 3.7” steel pulley from Maggie if you want to start off with lower boost. Take a look and let me know what you guys think.
I’m ready to get this out of my garage so if you’re in the lower 48 I’d go $3,000 shipped +PayPal fees if use. I’m open to offers, but it’s not like I need to move it fast.
Please take note that the case coating is a little rough and a couple of screws/bolts have some surface rust as seen in the pictures. So if you’re looking for a show piece, you’d need to take it apart and refinish or powder coat. There is no tuner with this kit so you will need a tune.
PM me with any offers or questions. I think I’ve been as up front as I can be. She works great she just aint real pretty. Thanks for looking!
Chris
