How often should plugs be changed if theyve been sprayed on?
Old 01-31-2012, 03:54 PM
its turbo time's Avatar
Default How often should plugs be changed if theyve been sprayed on?
Ive got some TR6's that saw about two bottles sprayed through them about 20k miles ago when i first swapped them. I havent sprayed since, will i need to swap them out before i spray a 100 again?
Whats the usual mileage interval on plugs that see n20? Thanks!
Old 01-31-2012, 06:35 PM
6 & 8 Second Club
mrdragster1970's Avatar
If you are not fine tuning your combination, there is no real time frame.
What I do is check for sharpness in the edges.
If you are pitting the piston, or fouling the plugs, obviously you want them out of there.
A good running combination should keep the plugs clean, and operating properly until you round over the edges.
Old 02-01-2012, 10:21 AM
Thanks! I'll chech them this weekend
Old 02-01-2012, 01:00 PM
87silverbullet's Avatar
Just letting you know that a TR6 is a projected tip plug but you are on a small shot. You might want to change out to a br6ef which is non projected just as a little insurance policy.
Old 02-01-2012, 02:40 PM
I have a set of br7efs that I haven't installed cuz I heard of people with daily driver issues with them. Maybe the br6ef would be a Good compromise
Old 02-05-2012, 09:34 AM
6 & 8 Second Club
I would never use a projected tip, but I know guys that do all the time with those tiny kits.
I would not worry, but next time you might think about getting fresh plugs without the projected tip.
Good luck.
