1989 camaro 377
1989 camaro 377
Year: 1989
Make: Chevrolet
Model: Camaro
Price: $4000
Mileage: 125000
Private or Dealer Listing: Private Listing
Location (State): IN
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
parts and the good
1974 sbc 400 2 bolt main
GM steel 350 crank (not turned)
scat H-beam rods
keith black silvolite hypo-forged pistons .30 over
sealed power piston rings
cam motion camshaft
comp cams lifters
trick flow chromoly push rods
harland sharp 1.5 roller rockers
1969 corvette 492 2.02 camel hump heads (gone through w/ 3 angle valve job new valve guides, valves, and springs)
dual spring valve springs good up to .625 lift
mr. gasket and felpro gaskets throughout
edelbrock performer rpm intake
edelbrock 1407 manual choke carb
comp cams double roller timing chain
king HP bearings throughout
GM pumkin distributor with accel coil
taylor 8.5mm spiral core wires
powerbond balancer
168 tooth sfi approved flex plate
mini starter
chrome oil pan
chrome valve covers
chrome timing chain cover
headman long tube headers
3 inch true dual exhaust with x pipe and flowmaster 10 series mufflers with 90 downs
turbo 350 trans with shift kit and kevlar clutches
hughes 2800 stall converter
aluminum 3 core radiator with dual 12 inch fans
richmond 3.42 gears
GM posi differential
msd street fire ignition
NO RUST in the wheel wells, fenders, doors, or quarters, there is a little rust on the underside of the car but its it very minimal and is great deffinatly being 22 years old
new duralast gold u joints
prosport guages - oil temp, water temp, narrow band a/f
front brakes have 5000 miles on them
shoes are new on the rear and drums were turned and are still very well in spec.
drums were rebuilt with new everything (wheel cylinders, springs, shoes, ect.)
tires have maybe 500 miles on them
new shocks all around
new sway bar end links all around
iroc z front and rear sway bar
iroc z wonder bar
iroc z quick ratio gear box
carpet was new when i bought the car
dash pad NOT cracked
pioneer 4x6 3 way front speakers
pioneer 6x9 5 way rear speakers
pioneer head unit
updated 3rd brake light with LED kit
the bad
** reason for low price**
fuel pressure is 6-6.5 psi at cold idle and then drops to 4 psi and stays there once warm, it will not drop farther then that. the fuel pump is run off the computer still with no sensors to read off of so im not sure if the computer goes into closed loop and will only give 4 psi.
the paint is deffinatly not the greatest and the front bumper cover is primered
the front window is cracked on the passenger side from top to bottum
the driver seat has about a 2 inch rip in it (typical)
the speedo and tach are off
the front seats are faded from being 22 years old
i do have about half a quart of blue for the bumper cover if wanted
call or txt me at 574-309-four four zero eight from 9am till 12pm
