5.3 crank in an LS2
Old 02-05-2012, 08:52 AM
turbocreeper's Avatar
Default 5.3 crank in an LS2
will it work? basically im considering swapping an ls2 shortblock for my ls1 and i know the reluctor wheels are different. i need the 24 not the 58 tooth. will be using everythig else off the ls1
Old 02-05-2012, 07:55 PM
chrisfrost's Avatar
Yes it will work with the correct reluctor wheel and You'll need to have the rotating assembly balanced because the LS2 or 3's pistons are a little heavier ,,,,,,,,,enough that the bob weights on the cranks are a little different between the 5.3L and the LS2 or 3
Quick Reply: 5.3 crank in an LS2
