408 guys...what heads/cam???
i have a set of Jantzer Motorsports ported 6.0 heads, but he never flowed them...i'm wondering if i just had some 2.02/1.60 valves installed and the chambers smoothed and the heads milled a bit would they be acceptable for a nitrous 408, or would i be better off selling them and getting something else. also, what cams/heads are you 408 guys running?
Thanks,
Matt
Thanks,
Matt
I am most likely going with stage 3 LS6 heads from TEA with 2.10 1.60 valves
Those heads you have will do but if your like myself and want everylast hp possible I would go with the LS6's. I am also waiting to see what AFR's new 225's will do. Cam is in sig but having a hard time with Comp making a cam with that big of lift?
