WTT 25.5 94' mustang
Year: 1994
Make: Ford
Model: Mustang
Price: $1
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): NJ
Color: Turquoise
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
94' mustang
25.5 chromoly chassis setup for bbc/glide built last summer by DC Performance
Body:
Schoneck 6" cowl hood
Team z wing
Dc performance parachute mount
Front suspension/steering:
Team z K-member
Team z adj A-arms
Team z C/C plates
Team z travel limiters
Dmc motor/mid plate and engine limiters
Racecraft 2 inch drop spindles
Racecraft manual rack & pinion
Racecraft bump steer kit
Racecraft bolt in tubular steering column
Strange quick release hub
Strange 10 way adj struts
Strange coil over kit for struts with 12" 170lb springs
Grant steering wheel
Rear suspension/housing:
Trz double adj uppers
Trz double adj lowers
Trz spherical upper bushings
Trz anti roll bar
Afco double adj coil overs and springs
8.8 rear housing
Narrowed 2inch per side
Axle tubes welded and braced
Ford 9 inch housing ends
Team z indexing lower controll arm mounts
Trz double shear coil over shock mounts
Moser rear cover
Powder coated black
Fuel system:
Weldon sportman pump
Weldon block regulator
Weldon pre and post pump filters
Chilsed 5 gallon cell
Wheels:
15x3.5 street lites
15x10 4.5bs street lites
Brakes:
Baer ss4 front and rear drag brakes
Hurst line lock
Wilwood proportioning valve
Racecraft manual master cylinder kit
Interior:
Kirkey seat
Racecraft kirkey seat mount
Lightened stock dash
Dzus in center consule
10lb fire supression system
Window net
Trunk mounted battery box with kill switch and charging post
All parts are brand new, some haven't even been installed on the car yet. Over $25,000 dollars invested in the chassis. Car needs motor, trans, wiring, plumbing, rear housing internals, and tires. Great start for someone looking to run in x275!
