Oil Pan Question For BMR Turbo K Member Users!
Do any of you guys know if there is enough room to just remove the pan with the added room from the Turbo K Member or do we still have to loosen the bolts and raise the motor?
I will be tackling this next week and would just like to know what i am in for!
Thanks Alot!
Thanks Alot!
Nope. With a Vic Jr intake I had to support the engine with a lift and unbolt/pull down the k-member to get the oil pan to clear the oil pickup. You might be able to just lift the engine and not drop the k-member with a stock intake.
LS1Tech Premium Sponsor
You are definitely going to have to lower the BMR turbo k-member down some to be able to get oil pan around the pick-up tube. You may also be able to lift the motor a little too. It really sound like more of an ordeal than it really is.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
