throttle body vacuum ports
Old 02-10-2012, 04:42 PM
cain_steven's Avatar
Default throttle body vacuum ports
i have a engine light one for either a bad MAF or a vacuum leak so i checked for leaks first and i saw a port on my throttle body that looks like it a rubber hose should be hooked up to it...so i covered it and drove around it seemed fine then, the next morning it ran horrible until i uncovered the port...
it is on driver side of TB on the bottom....anyone know what this is or know what it should be hooked up to?
Old 02-10-2012, 06:15 PM
mark21742's Avatar
Sounds like your canister purge valve solinod.....look along the drivers side where the intake and valve cover meet. There should be a plug and vacuum switch that has a hose running to that port on tb
Quick Reply: throttle body vacuum ports
