Help: cant get lock ring onto fuel pump? any suggestions?
currently fighting to put the lock ring that comes with the racetronix fuel pump onto the bottom are on fuel pump. the piece of the sock gets in the way when i try and use a drive socket. how did you guys do it if having the same issues? is there anything else to use besides that lock ring to keep the sock on the fuel pump and not loosen and come off?
thanks in advance
thanks in advance
