a4 guys (( heads and cam ))
Old 03-20-2004, 12:39 PM
indy500's Avatar
Default a4 guys (( heads and cam ))
what is best head and cam package that recommend for a4 c5 ?
i'm looking for more power and keep my car streetable
i see tsp offerd pp ls6 stage 2 with 231/237 cam ... is there any one use in a4 car , is it streetable
is it worth to just get cam with stock heads ? and which one good for my mode ?
my regards
Old 03-20-2004, 12:56 PM
LS1TECH Sponsor
foff667's Avatar
some of those questions you can anwser yourself really...if you want to save yourself $1000+ and can live with a rough idle go cam only and make decent power...if youve got the extra bucks you can go with heads/cam and make the same power with a better idle and driveability...there are hundreds of combos that work id really do a search, but first choose if you want a cam only or heads/cam car first for yourself just remember you can make big power either way just easier if you get heads and it can become less streetable real quick with a huge cam but no head work.
lata
Bill
Old 03-20-2004, 01:11 PM
slyws6's Avatar
I'm running the mods in my sig and it is very streetable, idle is set to 850rpm's and runs great. Just keep in mind you WILL need tuning for everything to work properly, and I would highly recommend some kind of tuning right off the bat because my car would run extremely hot with the factory fan settings. The combo you are looking at will be very streetable.
-Sly
Old 03-20-2004, 03:45 PM
indy500's Avatar
thanks ... i got the point now ...
Old 03-20-2004, 11:16 PM
JoSeY's Avatar
not in a C5 but in a 99 Formula with MTI Stg 2+ Heads and X1 cam with a 3dish 4000 stall....i was runnin high 10's on motor.....
Old 03-20-2004, 11:28 PM
Nick Agostino's Avatar
One of our customers in Chicago runs a 230/230 112 with our stage 3 5.3 (small bore) heads. Daily driver, dyno's 430+ (A4) and runs 10.70's
Old 03-21-2004, 12:57 AM
Hugger SS's Avatar
I have a 600+ lift cam...108 LSA on my daily driver
