Another rear main question
Ok so ive searched a bunch of threads and havent found this sort of issue. I had a 98 ls1 m6 car. I put in a 6.0 and the ls1 went in my silverado. Now the car had a slight rear main leak so i put a new seal in. Well put it all in and it was worse. So i thought maybe faulty seal...did some searching and when i did it the sexond time made sure to threadseal the flywheel bolts too. Still leaks...after looking on here im curious, i know people talk aboutnthe welch plug but wouldnt the input shaft kind of block the hole too? And the tc nippel on autos.cause when i pulled the trans this time it looks like its coming from inside the crank...running down and not running down from the seal itself. So long story short. Is it possible that because i never took out the pilot bearing the tc may not be seating all the way and sealing the crank? Sorry for the novel wanted to get the whole story known.
Thanks in advance!
Thanks in advance!
It can't leak out the inside of the crank. Its still most likley the seal. The crank could have a nick or a wear spot on the sealing surface which is causing your leak. The rear block cover also has a little o ring that seals against the rear of the block maybe its bad and causing your leak.
Not to call you a liar but there is a puddle of oil behind the pilot bearing. The seal and crank look fine no grooves or nicks. Slightly glazed where the seal rides is all. I'm tempted to pull the pilot and seal a freeze plug in it. Any suggestions?
It wouldn't have helped to see that. And I put it in like normal seals are with the taper out but until I saw the note with the new one I would have done it again. Still doesn't explain the oil behind the pilot...oh well just guna fill it with rtv.
