advancing cam increases intake PTV clearance
Old 02-16-2012, 05:37 PM
3rdCoastPowerSports's Avatar
Default advancing cam increases intake PTV clearance
does anyone know how much roughly advancing or retarding the camshaft would increase or decrease PTV clearance on the valves. for example if you install a cam strait up (cam is built with zero advance or retard) and then measure the PTV clearances of the valves. you get .100" intake PTV clearance and .120" exhaust PTV clearance. Then you advance the cam 2 degrees and re measure, what would you get (theoretically)?. does anyone know what the "factor" would be for this?
Old 02-16-2012, 06:10 PM
KCS
Moderator
KCS's Avatar
Too many variables, you just have to check it.
Quick Reply: advancing cam increases intake PTV clearance
