Sponsored by: DashLynx
AC delete panel?
Old 02-16-2012, 07:37 PM
fastredlt1's Avatar
Default AC delete panel?
This might be a stupid question! But i just received my BMR AC delete panel for my 97 TA. Is the panel suppose to be installed in the engine bay or from inside the car behind the dash?
Old 02-16-2012, 08:14 PM
djfury05's Avatar
I think BMR's is from the engine bay side
Old 02-16-2012, 08:25 PM
fastredlt1's Avatar
Ill have to give it a try. Just wanted to see how other's install theirs?
Old 02-16-2012, 11:49 PM
02CamZ28's Avatar
Yup pretty sure from engine bay side
Old 02-17-2012, 06:30 PM
fastredlt1's Avatar
I called BMR today and was told it gets installed inside the car. But I'm sure it can go both ways.
Old 02-18-2012, 12:32 PM
bww3588's Avatar
it is designed to be installed from inside the car. the flanges and other different metal angles will probably not allow you to install it from the engine bay side.
I made a custom one when I bashed my evaporator box to hell and it turned out very well. took about 30 minutes to make it, used a cardboard template and some thin sheet metal. drilled some holes and sealed it up with seam sealer.
Old 02-18-2012, 10:55 PM
fastredlt1's Avatar
I just installed the panel today, yes it gets installed from inside the car and it looks great. Thanks for all the help guys.
Quick Reply: AC delete panel?
