Western Members CA, AZ, NV, UT, CO, NM, HI
block off plate for fast 90 with egr fitting?
Old 02-19-2012, 02:17 PM
01SOMSS!'s Avatar
Default block off plate for fast 90 with egr fitting?
do they make a block off plate I can use on my fast 90 that I'll be using on my 01 SS? thanks.
Old 02-19-2012, 04:04 PM
MJs1FastSS's Avatar
Put a freeze plug in it... if youre talking about the egr port
Old 02-19-2012, 07:20 PM
MrElectric03's Avatar
Yea freeze plug that just the right size could easily be painted, easy option would be a rubber freeze plug but you would have a wingnut on top and would look like crap...definately wouldnt fit in under your hood lol.
Old 02-20-2012, 12:48 AM
01SOMSS!'s Avatar
Where can I get this freeze plug?
Old 02-21-2012, 11:24 PM
Measure the hole as close as you can or take the intake to an auto parts store. Back when I worked at Vatozone we kept some in stock. You want one that almost fits in but is VERY SLIGHTLY too big. If its too big and you force it you could crack the plastic.
Old 02-22-2012, 10:23 AM
01SOMSS!'s Avatar
Thanks
Quick Reply: block off plate for fast 90 with egr fitting?
