need help with pinion shim!
ok, so my old set of motive gears had a pinion depth marked as 2.292 on the pinion and the shim that was used with that set was a .031
now my new set of gears the pinion is marked 2.303 a total of .011 difference.
my question is do i add or subtract .011 from the .031 shim that was on the pinion of my old set?
