LQ4 truck intake injector options
Tried the performance section but didnt get a whole lotta help, so I'll try here.
What do you guys suggest for injectors on an LQ4 with the truck intake? Right now it has these shorty or mini Delphi's in there. Need either a 60 or 80lb injectors. Can a put a set of the taller types in there? Seem to be a little cheaper.
I will be using a Holley ECU which uses a minitimer/EV1 connector - would like to reuse this harness if poss.
Thanks
Vince
Thanks
Vince
