Stock LS3 fuel rails with -8 An's welded on. Questions
Just bout an LS3 with a stock set up almost exactly like this. Seems like a hassle to run dual feed lines instead of just one feed a cross over and a return out of the reg. Its s TT set up going into a 67 El - Camino. Anyone got any advice on if should stick with this set up or just get an easier to plumb aftermarket set up. Advantages / Disadvantages.
Thanks Tony
Thanks Tony
11 Second Truck Club
What are the stock rails made out of....Stainless?? I am building a combo right now using a LS3 manifold and injectors, and really like the stealthinesss of the stock rails but I need a return. It would be great if I could just weld some fittings to the stock rail!
