GTO performance suspension
Category: Steering & Suspension
Price: $100
Part Fits: 2010+ Camaro, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): PA
Item Condition: Used
LS Engine?: Fits LS Engine
Pedders adjustable poly radius rod bushings $75
Full front suspension including cradle
Monroe front struts $75 pair
Eibach 1.2" drop springs $75
Most of the other bushing I have are Energy Suspension poly bushings
Home built and setup big brake kit using 2011 Camaro 14" drilled and slotted rotors
CTS-V front 4 piston calipers in the front
GTO 2 piston calipers in the rear
Id like to sell the brake/ front hub assy together as a kit for $500
Rear cradle
Stock diff with stock 346 gears (no noise or clunking) $350
Stock hubs
Stock axles $150
B&M Mega shifter modded for 4l60 $100
4l60 $200 (needs tail shaft, front pump or used for parts)all hard parts should still be good Beast sun shell, raptorR input kit, 5 pin planets
I know I'm supposed to say prices on all, but will take offers on everything, if its not listed ask, I might have it
Thank you for looking!
The bushing have about 20,000 miles on them, and here are a few pics of the brakes behind 18" wheels. You will need 18" or larger wheels to fit the brakes
Front setup
Final adjustments to the rear
Stock GTO front caliper and one that has been ground down to fit in my rear wheels
Front setup
I'll have to dig up pics of the front setup and post them here after a while
Any special shots you want? It is all apart at my house right now, so let me know
