Generation IV External Engine - What fitting for Corvette power steering pump?
samckitt
02-27-2012, 11:51 AM
Trying to find a fitting for a C5/C6 Corvette power steering pump to steering box. Is this what I need:
http://www.detroitspeed.com/productsall/090401-psp-otlt-fttng.html
http://www.detroitspeed.com/images/090401-main-pp.jpg
S10xGN
02-27-2012, 07:43 PM
That's the HP port from the pump to the rack. The one from DSE will have a different flow/pressure rate than a stock GM fitting. Why are you changing it?
samckitt
02-27-2012, 08:20 PM
I don't have anything presently. I was under the impression I would need a special fitting for it. Do I just get a GM fitting for it?
S10xGN
02-28-2012, 07:38 PM
I ended up with a reman from Advance and the fitting came with the pump...
Project GatTagO
03-14-2012, 09:37 PM
If you want to install a fitting in the Corvette pump that has a AN-6 out, then Earls makes one.
Andrew
thenovaproject
03-19-2012, 10:43 AM
M16 1.5 to an6
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
