Honing with a deck plate?
Old 03-22-2004, 01:56 AM
JS
JS's Avatar
Default Honing with a deck plate?
If I hone my block with a deck plate can I RE-USE my stock replacement pistons r will this cause me to have leakdown porblems?I used GM rings (That were File fit) after honing the block if that matters?
JS
Old 03-22-2004, 11:11 AM
Taspeed's Avatar
as long as you file fit them AFTER the honing you will be ok. I would never use a block that wasn't honed with deck plates FYI.
Old 03-22-2004, 11:24 AM
Cstraub's Avatar
FYI, if the shop doesn't have an LS1 torque plate, have them use a SB Ford. It will work.
Chris
Old 03-22-2004, 01:42 PM
JS
JS's Avatar
I used a Ford deck plate..
Thanks Cstraub,I think maybe my PR heights are wrong and are hanging a valve open?
Gonna check PR length,leakdown Wed night.
JS
Quick Reply: Honing with a deck plate?
