Critique fuel system plan for turbo
Old 03-01-2012, 05:35 PM
Lambert695's Avatar
Default Critique fuel system plan for turbo
So I am building a front mount turbo with a stock cube LS1 and a pt76GTS.
Plans
two 255lph walbaros (GSS340)
-8 Fuelab filter
-8 Feed
-6 Return
Fuelab boost referenced regulator
Speed inc fuel rails
Mototron 60# injectors
Hobbs switch
Racetronix wiring harness for 98
So my question I guess it how would you set up the fuel rails. I was going to feed them with -8 hose then Y off into the back of the rails then have the front of the rails come out into each side of the regulator and then -6 down.
The problem and I dont know if Im not looking hard enough but I can't find a regulator for -8 fittings. so would it be bad to reduce down to a -6 fitting at the regulator? or can I take my -8AN line and reduce it down to -6 AN at the back of the fuel rails?
Old 03-01-2012, 05:46 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
I build these kits all the time with Fuelabs components.
Free to give me a call if you are interested in a fuel system.
I have the parts in stock.
Old 03-01-2012, 09:46 PM
Lambert695's Avatar
I would if I could afford it, which is why im just making my own system. Just want to make sure the way I was gonna do it will work fine
Old 03-04-2012, 11:58 PM
Lambert695's Avatar
well i guess Im having trouble getting some responses, so I will just ask one more question.
Is there anything wrong with running my rails parallel? Have them y off in the back with a line to each rail then have them meet in the front with a regulator..
Old 03-05-2012, 09:45 AM
FastKat's Avatar
That should be fine... it might actually be the ideal way to do it.
Old 03-05-2012, 03:35 PM
LS1NOVA's Avatar
That will work good.
Old 03-05-2012, 05:19 PM
Lambert695's Avatar
Cool thanks guys!
And does anyone know the ideal time to have a hobbs switch kick the second pump on?
Old 03-05-2012, 05:47 PM
LS1NOVA's Avatar
Mine kicks on at 4psi as thats an easy hobbs switch to find. If anyone knows of a 1 psi option Id like to know too. That would be ideal.
Old 03-05-2012, 06:02 PM
Lambert695's Avatar
I thought they were adjustable? I thought I saw one that went from 1-15psi. I probably read it wrong though.
Old 03-06-2012, 07:55 AM
MIGHTYMOUSE's Avatar
run the 8 to the back of the passenger rail, 6 or 8 cross to the front of the driver rail, 6 out the back to the regulator.
will save you about a hundred bux in y's and AN fittings.
Old 03-06-2012, 08:57 AM
Lambert695's Avatar
I wasn't to worried about money, I just want to make sure that all injectors will get fuel at all times and efficiently.
Old 03-06-2012, 09:19 AM
LS1NOVA's Avatar
They will either way you do it. The Y method would take you farther horsepower wise but your not looking to make 1200rwhp so Id agree with MM and save your money.
Old 03-06-2012, 10:15 AM
if you arent worried about money buy my fuel system for 35k and it will come already hooked up to a mid 8 second car.
