LS4 Performance - Will LS4 fuel rail fit on LS1/LS6 intake?
FastKat
03-02-2012, 12:26 PM
I did some searching but I can't seem to find a thread that squarely addresses this...
Will an LS4 fuel rail mount up to an LS1/LS6 intake manifold? Is the bolt pattern and injector location the same?
From what I understand, the LS4 injectors are a little shorter, so I might need to raise the LS4 rail up a little bit using shims... or I could get some shorter LS4 injectors.
Any info will help!
neilownz
03-02-2012, 04:43 PM
I believe it needs to be bent a little and/or the plastic needs to be sanded some. Or you can cut out a section of the middle and replace it with some -6 an hose and fittings. Or you can use a different fuel rail.
FastKat
03-02-2012, 06:32 PM
Thanks for the info. I found a writeup from a Grand Prix forum and it sounds like the mounts need bent and the rail needs shimmed to increase its height.
neilownz
03-02-2012, 07:21 PM
There is more than one way to make it work, but it is not a direct fit.
