Racetronix 255 F Body fuel pump
Category: Engine - Intake/Fuel
Price: $80
Part Fits: 93-02 Pontiac Firebird
Location (State): SC
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Comes with pigtail and sock I also have the black rubber casing it sits in not shown in the pic.
Pump has just over 20K on it and was removed in perfect running condition last week.
You may or may not be able to use the plastic fuel hose. The top 1/4" was cut because I couldn't get it to slip of the sending unit. Its captured in the pic.
80 Shipped!
[IMG][/IMG]
Good price 70 dollars cheaper than new, everything here to run it unless you want the the racetronix harness too. Can be had at there site for 59.95 and you save yourself about 80 dollars then.
Complete kit with racetronix harness. (Not required, but recommended if your trying to push the pump.) 209.98
http://www.racetronix.biz/customkiti...c=RFPK-001&eq=
Wiring harness. 59.95
http://www.racetronix.biz/itemdesc.a...WH-001&eq=&Tp=
buy the pump from me then the harness you still save 80 on the entire system.
ttt
ttt
