need help with coolant crossover bolt thread size
i need help with figuring out the thread size on the bolts that mount the coolant crossover tube to the cylinder head. i purchased a brand new set of take off 799 heads for cheep because the threads are stripped in one of the bolt holes for the coolant tube. i plan on fixing this by installing a heli coil but i need to know the thread size first.
get a thread pitch guage and check one of the bolts that will tell you the pitch of the bolt and if you dnt have a bolt take your other head and check its pretty easy
i had this happen to me dnt remember pitch though good luck and you may be able to chase it try that first
