longtube headers installed rubbing issues
just installed my stainless long tube headers and the driver side header is rubbing on a metal rod on the K-member it goes from back where the A-arm bushings are located to the front of the k-member it is held in place by two bolts does this piece matter as far as being support on the K-member or can i just remove it?
mark where its hitting, take it off put it in a vice and bend it slightly, then open the holes a bit.... youll be fine... You could also take it off but if it were me, id try to make it fit..
haha i just installed ebays last saturday. fit like a glove. getting custom duals installed today. didnt even have to widen any bolt holes. i dont have that bracket either i would just remove it
you having a vert, you have all weird kind of little stabilizer bars and **** on your K-Member. Prob just bend it or take it off really. I have OBX headers as well and the steering shaft hitting on the pipe was my issue.
Well I fixed the problem with the stabilizer bar and I'm still rubbing the four primary tubes coming down in between the k-member on the driver side are still rubbing looks like i could cut the k-member so they could clear but should I just try something else instead of hacking away at it? It's a let down on all the hard work it took to get them in there and now I have problems:/
