Aeromotive 340 in a F-body
Old 03-06-2012, 02:04 PM
1bad99's Avatar
Default Aeromotive 340 in a F-body
Anyone know if and what mods would i need to do to drop a aeromotive 340 into my tank. Its a stock fuel system. Or would a Walbro 255 be enough to produce 600rwhp? Thats a ball park number
Old 03-07-2012, 08:03 PM
12sws27's Avatar
I put a aeromotive 340 in my 98 GMC Jimmy. I used the walbro install "how to on here" as a guide. There were a few things I had to do differently but not many. My pump in my Jimmy and your in your f-body or pretty much the same in the way they work.
The aeromotive 340 it also the same size as the walbro. So you could almost follow the walbro install "how to" on here exactly.
If that 600 hp you have/want is from all engine then Racetronix has a pump just for your car. It'll come with great instructions and they will gladly help you with anything else you need. Like a all in one kit that includes the pump and a wiring harness to upgrade the wiring to the pump. A pump that flows more fuel will also draw more current and upgrading the wiring to it will make sure the pump works to it's full potential.
Old 03-07-2012, 10:42 PM
MASS seller approved
smok'nZ's Avatar
aero 340 is supposed to be a direct swap
Old 03-08-2012, 07:50 AM
1bad99's Avatar
Thanks guys. Ill def check out racetronix. I have a few friends that are running the aeromotive but none of them have F-bodies, they either have Goats or Stangs. So wasnt sure how close the setup would be.
Quick Reply: Aeromotive 340 in a F-body
